Trying to create an extractor for input via API
Hi everyone,
So basically I’m getting 404 whenever I do POST request to /system/inputs/{inputID}/extractors, however, I’m 100% positive that the input is there.
This is how my payload looks like:
extractor_payload = json.loads(
‘’’{“title”:“FluentD”,“extractor_type”:“json”,“converters”:{},“order”:0,“cut_or_copy”:“copy”,“source_field”:“kubernetes”,“target_field”:"",“extractor_config”:{“list_separator”:",",“kv_separator”:":",“key_prefix”:"",“key_separator”:"",“replace_key_whitespace”:false,“key_whitespace_replacement”:""},“condition_type”:“none”,“condition_value”:""}’’’)
If I do the same from browser-api, works just fine(meaning if I copy/paste the same payload).
I’ve tried all the headers in my script. I’ve made sure that, I create an input first and then use inputs ID to create an extractor, however, still getting 404. I also tried manually passing inputs ID, still no luck.
I appreciate your time,
Thanks.
Could you share the full cli command how do you do it?
maybe you missed to inform GL you will send the information in json. But I think, it won’t give a 404 in this case.
// Of course, with masked ip, username, and pass.
So this is a command that does it:
self.url = f'http://{self.options.ip_address}:9000'
self.extractor_path = "/system/inputs/{0}/extractors"
self.headers = {'X-Requested-By': 'cli'}
self.extractor_payload = json.loads(
            '''{"title":"FluentD","extractor_type":"json","converters":{},"order":0,"cut_or_copy":"copy","source_field":"kubernetes","target_field":"","extractor_config":{"list_separator":",","kv_separator":":","key_prefix":"","key_separator":"_","replace_key_whitespace":false,"key_whitespace_replacement":"_"},"condition_type":"none","condition_value":""}''')
response = requests.post(self.url + self.extractor_path.format(input_id), headers=self.headers,
                                     json=self.extractor_payload, auth=(self.user, self.password))
Please let me know if the above doesn’t make sense, but like I’ve said, if I manually copy/paste JSON payload and paste it into browser-api, works just fine.
Also I’ve made sure that I’m generating the right URL and getting inputs ID. I know, I’m probably missing something small, but it has been driving me crazy.
Thank you.
Let me beatify this JSON:
  "title": "FluentD",
  "extractor_type": "json",
  "converters": {},
  "order": 0,
  "cut_or_copy": "copy",
  "source_field": "kubernetes",
  "target_field": "",
  "extractor_config": {
    "list_separator": ",",
    "kv_separator": ":",
    "key_prefix": "",
    "key_separator": "_",
    "replace_key_whitespace": false,
    "key_whitespace_replacement": "_"
  "condition_type": "none",
  "condition_value": ""
I think you should use username an password also.
I suggest to start with curl, test it from cli, and if it’s working well.
I do pass username and pass here - auth=(self.user, self.password). This is just a small piece from the script. Using the same headers and credentials I have a method that creates an input first and then passes the inputs ID to another method that creates an extractor.
I don’t have any issues creating an input, however, I’m getting 404 when it comes to extractor.
I’ll do it from the cli as well, but don’t think it makes any difference.
I get the same response doing the API call from the cli as well:
curl -u $user -X POST http://localhost:9000/system/inputs/5e864e399c26da1d7d18d1ac/extractors -H "X-Requested-By: cli" -d "{"title":"FluentD","extractor_type":"json","converters":{},"order":0,"cut_or_copy":"copy","source_field":"kubernetes","target_field":"","extractor_config":{"list_separator":",","kv_separator":":","key_prefix":"","key_separator":"_","replace_key_whitespace":false,"key_whitespace_replacement":"_"},"condition_type":"none","condition_value":""}"
Enter host password for user '$user':
{"type":"ApiError","message":"HTTP 404 Not Found"}
However input is there, please see below attached.
Thanks.
Screen Shot 2020-04-02 at 4.25.41 PM
Hi @zohan,
you made a small mistake, which is why you get 404:
Use use http://localhost:900/system/input/xxxx/extractors, but you forgot to use api. So correct URL will be:
http://localhost:9000/api/system/inputs/5e864e399c26da1d7d18d1ac/extractors
I tried your example usign curl and everything worked as expected:
curl -i -X POST -u admin:password -H 'Content-Type: application/json' -H 'X-Requested-By: cli' 'http://localhost:9000/api/system/inputs/5e611e345c544d030fc8148e/extractors' -d '{"title":"FluentD","extractor_type":"json","converters":{},"order":0,"cut_or_copy":"copy","source_field":"kubernetes","target_field":"","extractor_config":{"list_separator":",","kv_separator":":","key_prefix":"","key_separator":"_","replace_key_whitespace":false,"key_whitespace_replacement":"_"},"condition_type":"none","condition_value":""}'
nice catch. but it is easier if he shares the full link :slight_smile:
Hi @shoothub,
Thank you much for that catch. I can’t believe I’ve missed it. I knew it was something small.
Thanks again, this can be closed.
