Tor_lookup() always returns {threat_indicated:false}
It has been reported here before, and it seems to be a common topic: tor_lookup(“ip-as-a-string”) always returns {threat_indicated:false}.
I checked this by;
  • testing if a current tor exit node can be found in the list using the “Test lookup” feature under the System/Lookup Tables. This returns something like
  "single_value": "YADA....YADA",
  "multi_value": {
    "node_ids": [
      "YADA....YADA"
  "ttl": 922...6000
  • I added a pipeline function and hardcoded the call using the very same IP address like
rule "test_threat_intel"
  has_field("src_ip")
  let intel = tor_lookup("TESTIP");
  set_field("src_ip_is_tor_exit_node", intel.threat_indicated);
  set_field("test", to_string(intel));
and I always get
test: “{threat_indicated=false}”
and
src_ip_is_tor_exit_node: false
as a result.
Obviously, this is also true when I use the real ip for the lookup like in
tor_lookup(to_string($message.src_ip))
So clearly - something is wrong.
Any ideas???
It looks like this is already reported as a bug: https://github.com/Graylog2/graylog2-server/issues/4539
Feel free to subscribe to the Github issues to get updates on that.
I now commented on the issue. I already stumbled across it, but because latest comments were from Feb 2018 I though to give it a try here. I take it that nobody currently uses this… :slight_smile:
or nobody that is using notice this. I have pointed one of the developers into this. Hopefully a fix will come up with the next version.
