Timestamp change pipeline
I want to change the time of my logs timestamp by reducing 3 hours from it timestamp.
rule "set timestamp"
  $message.source == "example.org"
  let new_timestamp = parse_date(to_string($message.timestamp), "yyyy-MM-dd HH:mm:ss");
  ***new_timestamp = new_timestamp-3;***
  set_field("timestamp", new_timestamp);
The starred line is not correct. How can I fix it?
Have you seen this.
