The local input isn't running
the local input isn’t running
  • OS Information:
    centos stream release 9
  • Package Version:
    graylog5.1+opensearch2.9+mongodb 6.0.9
    Graylog log*********
    2023-09-01T05:23:54.255-04:00 INFO [InputStateListener] Input [Syslog UDP/Logo/64f1a5f679672616c2bdbdca] is now STOPPED
    2023-09-01T05:23:54.259-04:00 INFO [InputStateListener] Input [Syslog UDP/Logo/64f1a5f679672616c2bdbdca] is now TERMINATED
    2023-09-01T05:23:54.262-04:00 INFO [InputStateListener] Input [Syslog UDP/Logo/64f1a5f679672616c2bdbdca] is now STARTING
    2023-09-01T05:23:54.268-04:00 ERROR [InputLauncher] The [org.graylog2.inputs.syslog.udp.SyslogUDPInput] input [Syslog UDP/Logo/64f1a5f679672616c2bdbdca] misfired. Reason: bind(…) failed: Cannot assign requested address.
    org.graylog2.plugin.inputs.MisfireException: org.graylog2.plugin.inputs.MisfireException: io.netty.channel.unix.Errors$NativeIoException: bind(…) failed: Cannot assign requested address
    at org.graylog2.plugin.inputs.MessageInput.launch(MessageInput.java:167) ~[graylog.jar:?]
    at org.graylog2.shared.inputs.InputLauncher$1.run(InputLauncher.java:94) [graylog.jar:?]
    at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:180) [graylog.jar:?]
    at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source) [?:?]
    at java.util.concurrent.FutureTask.run(Unknown Source) [?:?]
    at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [?:?]
    at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [?:?]
    at java.lang.Thread.run(Unknown Source) [?:?]
    Caused by: org.graylog2.plugin.inputs.MisfireException: io.netty.channel.unix.Errors$NativeIoException: bind(…) failed: Cannot assign requested address
    at org.graylog2.inputs.transports.UdpTransport.launch(UdpTransport.java:136) ~[graylog.jar:?]
    at org.graylog2.plugin.inputs.transports.Transport.launch(Transport.java:35) ~[graylog.jar:?]
    at org.graylog2.plugin.inputs.MessageInput.launch(MessageInput.java:164) ~[graylog.jar:?]
    … 7 more
    Caused by: io.netty.channel.unix.Errors$NativeIoException: bind(…) failed: Cannot assign requested address
    2023-09-01T05:23:54.270-04:00 WARN [UdpTransport] Failed to start channel for input SyslogUDPInput{title=Logo, type=org.graylog2.inputs.syslog.udp.SyslogUDPInput, nodeId=488c6f3f-553d-476f-8294-b8484cdb2e28}
    2023-09-01T05:23:54.271-04:00 INFO [InputStateListener] Input [Syslog UDP/Logo/64f1a5f679672616c2bdbdca] is now FAILED
opensearch configuration*********
cluster.name: graylog
path.data: /var/lib/opensearch
network.host: 0.0.0.0
http.port: 9200
discovery.type: single-node
plugins.security.ssl.transport.pemcert_filepath: esnode.pem
plugins.security.ssl.transport.pemkey_filepath: esnode-key.pem
plugins.security.ssl.transport.pemtrustedcas_filepath: root-ca.pem
plugins.security.ssl.transport.enforce_hostname_verification: false
plugins.security.ssl.http.enabled: true
plugins.security.ssl.http.pemcert_filepath: esnode.pem
plugins.security.ssl.http.pemkey_filepath: esnode-key.pem
plugins.security.ssl.http.pemtrustedcas_filepath: root-ca.pem
plugins.security.allow_unsafe_democertificates: true
plugins.security.allow_default_init_securityindex: true
plugins.security.authcz.admin_dn:
  • CN=kirk,OU=client,O=client,L=test, C=de
plugins.security.audit.type: internal_opensearch
plugins.security.enable_snapshot_restore_privilege: true
plugins.security.check_snapshot_restore_write_privileges: true
plugins.security.restapi.roles_enabled: [“all_access”, “security_rest_api_access”]
plugins.security.system_indices.enabled: true
plugins.security.system_indices.indices: [“.plugins-ml-config”, “.plugins-ml-connector”, “.plugins-ml-model-group”, “.plugins-ml-model”, “.plugins-ml-task”, “.opendistro-alerting-config”, “.opendistro-alerting-alert*”, “.opendistro-anomaly-results*”, “.opendistro-anomaly-detector*”, “.opendistro-anomaly-checkpoints”, “.opendistro-anomaly-detection-state”, “.opendistro-reports-", ".opensearch-notifications-”, “.opensearch-notebooks”, “.opensearch-observability”, “.ql-datasources”, “.opendistro-asynchronous-search-response*”, “.replication-metadata-store”, “.opensearch-knn-models”]
node.max_local_storage_nodes: 3
Graylog configuration*********
is_leader = true
password_secret = mD2lN8CSXU7ukwbblBba5BW77oP2ISnG7L1HPrZxojzOqohnOJUP
root_password_sha2 = deae401f7aadd4cb506e733d7a84615
root_timezone = Asia/Shanghai
http_bind_address = 10.210.82.20:9000
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
rsyslog configuration*********
global(workDirectory=“/var/lib/rsyslog”)
module(load=“builtin:omfile” Template=“RSYSLOG_TraditionalFileFormat”)
module(load=“imuxsock” # provides support for local system logging (e.g. via logger command)
SysSock.Use=“off”) # Turn off message reception via local log socket;
# local messages are retrieved through imjournal now.
module(load=“imjournal” # provides access to the systemd journal
UsePid=“system” # PID nummber is retrieved as the ID of the process the journal entry originates from
StateFile=“imjournal.state”) # File to store the position in the journal
include(file=“/etc/rsyslog.d/*.conf” mode=“optional”)
module(load=“imudp”) # needs to be done just once
input(type=“imudp” port=“514”)
*.info;mail.none;authpriv.none;cron.none /var/log/messages
authpriv.* /var/log/secure
mail.* -/var/log/maillog
cron.* /var/log/cron
.emerg :omusrmsg:
uucp,news.crit /var/log/spooler
local7.* /var/log/boot.log
.@10.210.82.20:1514;RSYSLOG_SyslogProtocol23Format
i don’t know how to check the issue.
Ports below 1024 are protected, so you can’t just use them without additional steps, from your log it’s refusing to allow it to bind to the address/port, most likely that is the cause. If you can just run the input on 1514 and have the sources send to that port it probably will work just fine.
