we’re getting indexing failure every week on index set that has high traffic.
ElasticsearchException[Elasticsearch exception [type=illegal_argument_exception, reason=no write index is defined for alias [xxx_deflector]. The write index may be explicitly disabled using is_write_index=false or the alias points to multiple indices without one being designated as a write index]]
Every time, there are 2 indices marked as deflector. I can resolve the issue by removing the alias from one of the indices, but this is happening weekly.
If that post does not resolve your issue could you show use the results of what happened?
Also to help you further, greater detail about you environment would be appreciate like extractors , pipelines, types of inputs used, index mapping, etc…
@gsmith Thank you for a quick respond! I’ve seen the article above and the steps in that article does resolved my issue. However, my issue has been coming back weekly for the last 3 weeks.
Here are my current environment settings:
GELF TCP and 1 Syslog TCP inputs
3 index sets
Index set configuration:
4 shards
1 replica
20000000 docs per index
Max # of Indices: 200
retention strategy: deletion
So far, we only have issue with one of the index set that has high traffic and going thru the index retention strategy (deletion).
I haven’t try to change the retention to 1 day yet. Surprisingly, it has been working fine for at least 1 week which was not the case. I will change the retention policy if it happens again. I would love to upgrade to 4.1 since it has native Prometheus support. Do you know from 4.0.8 to 4.1, do I also need to upgrade MongoDB and ElasticSearch? Below are the CPU/Memory/Disk IO
Thanks @gsmith. I’ve upgrade all my nodes to 4.1.7. I will let you know if the issue ever come back but so far it’s good (finger cross)
BTW, I’m also having another issue where all my nodes think they’re master node. I have 3 nodes cluster graylog-01, graylog-02, and graylog-03. I only specified is_master in the server.conf for graylog-01. Graylog Web is seeing all the nodes as master. I do see the a notification about multiple master servers everytime I restart any of the node.
