TCP Syslog does not work
Hello ,
I have the 2.5.1 ova of graylog and i send logs from linux Red Hat by syslog to the server.
The server shows logs sent by udp but for tcp i do not have incoming logs.
The rsyslog conf for udp is . @graylog.example.org:5140;
and for tcp : . @@graylog.example.org:5143;
I tried with . @graylog.example.org:5143;RSYSLOG_SyslogProtocol23Format without success
I disabled the firewall on linux and graylog server for the test.
@ is for udp and @@ is for tcp.
Do you check if Graylog is listening on TCP 5143 ?
Do you check /var/log/messages or /var/log/syslog if rsyslog says an error ?
i tested for tcp both
@@graylog.example.org:5143;RSYSLOG_SyslogProtocol23Format
In my graylog client i have input for tcp listening to 5143.
I even tested for tcp on 5140 where udp worked.
On my linux /var/log/syslog i have
“registered tcp module” and “registered udp module”
In /var/log/messages i got “TCP established”
On graylog:
  • /var/log/syslog does not have error
  • /var/log/messages does not exist
