I am currently experiencing an issue related to a high number of unprocessed messages in my Graylog cluster.
Within a very short period of time (approximately 1 minute), the number of unprocessed messages can spike to hundreds of thousands, even though all nodes are in a RUNNING state and message processing is enabled.
Environment:
Graylog cluster (multi-node setup)
All nodes status: Running, Load Balancer Alive
JVM heap usage appears normal (approximately 1–4 GB per node)
Journal messages continue to accumulate
Issue:
Sudden spike in unprocessed messages
Processing throughput is unable to keep up with incoming log volume
Potential delay in log visibility and alerting
Questions:
What are the most common root causes for this behavior?
What is the recommended approach to identify the bottleneck (e.g., CPU, disk I/O, journal, or input rate)?
What tuning steps are recommended to reduce the number of unprocessed messages?
Would it be more appropriate to scale horizontally (add more nodes) or optimize the existing configuration first?
