Hi, I’m using Graylog 5.2.5. I’m trying to parse a simple Json string.
I’m using the “Source Code Editor”
Here is my Rule Source:
rule “test”
has_field(“message”)
let json = parse_json(to_string($message.message));
let map = to_map(json);
set_fields(map);
and here is my Rule Simulation Message:
message: {“id”: “123”}
source: test
if I click “Run rule simulation” I got the following error message in der sever.log:
2024-03-22T19:23:28.027+01:00 WARN [JsonParse] Rule Unable to parse JSON
com.fasterxml.jackson.core.JsonParseException: Unexpected character (‘i’ (code 105)): was expecting double-quote to start field name
at [Source: (String)“{id:123}”; line: 1, column: 3]
at com.fasterxml.jackson.core.JsonParser._constructError(JsonParser.java:2477) ~[graylog.jar:?]
at com.fasterxml.jackson.core.base.ParserMinimalBase._reportError(ParserMinimalBase.java:750) ~[graylog.jar:?]
at com.fasterxml.jackson.core.base.ParserMinimalBase._reportUnexpectedChar(ParserMinimalBase.java:674) ~[graylog.jar:?]
at com.fasterxml.jackson.core.json.ReaderBasedJsonParser._handleOddName(ReaderBasedJsonParser.java:1940) ~[graylog.jar:?]
at com.fasterxml.jackson.core.json.ReaderBasedJsonParser.nextFieldName(ReaderBasedJsonParser.java:968) ~[graylog.jar:?]
at com.fasterxml.jackson.databind.deser.std.BaseNodeDeserializer._deserializeContainerNoRecursion(JsonNodeDeserializer.java:536) ~[graylog.jar:?]
at com.fasterxml.jackson.databind.deser.std.JsonNodeDeserializer.deserialize(JsonNodeDeserializer.java:100) ~[graylog.jar:?]
at com.fasterxml.jackson.databind.deser.std.JsonNodeDeserializer.deserialize(JsonNodeDeserializer.java:25) ~[graylog.jar:?]
at com.fasterxml.jackson.databind.deser.DefaultDeserializationContext.readRootValue(DefaultDeserializationContext.java:323) ~[graylog.jar:?]
at com.fasterxml.jackson.databind.ObjectMapper._readTreeAndClose(ObjectMapper.java:4867) ~[graylog.jar:?]
at com.fasterxml.jackson.databind.ObjectMapper.readTree(ObjectMapper.java:3219) ~[graylog.jar:?]
at org.graylog.plugins.pipelineprocessor.functions.json.JsonParse.evaluate(JsonParse.java:55) ~[graylog.jar:?]
at org.graylog.plugins.pipelineprocessor.functions.json.JsonParse.evaluate(JsonParse.java:35) ~[graylog.jar:?]
at org.graylog.plugins.pipelineprocessor.ast.expressions.FunctionExpression.evaluateUnsafe(FunctionExpression.java:63) ~[graylog.jar:?]
at org.graylog.plugins.pipelineprocessor.ast.expressions.Expression.evaluate(Expression.java:36) ~[graylog.jar:?]
at org.graylog.plugins.pipelineprocessor.ast.statements.VarAssignStatement.evaluate(VarAssignStatement.java:33) ~[graylog.jar:?]
at org.graylog.plugins.pipelineprocessor.ast.statements.VarAssignStatement.evaluate(VarAssignStatement.java:22) ~[graylog.jar:?]
at org.graylog.plugins.pipelineprocessor.processors.PipelineInterpreter.evaluateStatement(PipelineInterpreter.java:399) ~[graylog.jar:?]
at org.graylog.plugins.pipelineprocessor.processors.PipelineInterpreter.executeRuleActions(PipelineInterpreter.java:383) ~[graylog.jar:?]
at org.graylog.plugins.pipelineprocessor.processors.PipelineInterpreter.evaluateStage(PipelineInterpreter.java:335) ~[graylog.jar:?]
at org.graylog.plugins.pipelineprocessor.simulator.RuleSimulator.simulate(RuleSimulator.java:68) ~[graylog.jar:?]
at org.graylog.plugins.pipelineprocessor.rest.RuleResource.simulate(RuleResource.java:186) ~[graylog.jar:?]
at jdk.internal.reflect.GeneratedMethodAccessor948.invoke(Unknown Source) ~[?:?]
at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:568) ~[?:?]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory.lambda$static$0(ResourceMethodInvocationHandlerFactory.java:52) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:134) [graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:177) [graylog.jar:?]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$TypeOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:219) [graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:81) [graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:478) [graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:400) [graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:81) [graylog.jar:?]
at org.glassfish.jersey.server.ServerRuntime$1.run(ServerRuntime.java:255) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:248) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:244) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:292) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:274) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:244) [graylog.jar:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:265) [graylog.jar:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:234) [graylog.jar:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:684) [graylog.jar:?]
at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.service(GrizzlyHttpContainer.java:356) [graylog.jar:?]
at org.glassfish.grizzly.http.server.HttpHandler$1.run(HttpHandler.java:200) [graylog.jar:?]
at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:180) [graylog.jar:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) [?:?]
at java.lang.Thread.run(Thread.java:840) [?:?]
Whats the problem here?
