Simple searches not returning the right results even though I see them in the message section
I’ve checked and I haven’t seen anyone mention this so maybe it’s just me…
I’m getting my logs out of Azure (NSG Flowlogs) via logtsash and into Graylog this appears to be working great.
I see all the messages coming in at the bottom of the search page and I see all the fields that I’ve mutated etc… in Logstash. However, I can’t seem to search or at best it’s very hit and miss.
Example : For some reason I can’t do searches for destPort:8080 (Destination Port) field but sometimes I can on other fields. I don’t get any error back I just get a load of results back but the wrong ones (e.g. 443). same with IP
The crazy thing is, I was working to get the logs into Graylog and making them look right via the logstash conversion and I was thinking search would be the easy part.
I’m running v2.4.3+2c41897 if anyone has any thoughts I would really appreciate it
Hass
Please provide some example messages, as well as the configuration of Logstash in your setup.
Thanks Jochen, see the information below. as I said trying to search on “destPort:8010” fails.
NOTE that I use two static fields in the logstash.conf.
"short_message" => "hass test short_message"
"host" => "testserver"
This was to remove warnings in Graylog related to host and also an error when it was processing some messages.
Example of how the messages section looks in Graylog:
Timestamp destIp destPort srcIp srcPort time
2018-02-18 15:37:30.499 172.16.1.4 8010 13.129.107.213 35270 2018-02-18T15:36:15.4721718Z
2018-02-18 15:37:30.499 172.16.1.4 8008 13.129.107.213 47508 2018-02-18T15:36:15.4721718Z
2018-02-18 15:37:30.499 172.16.1.4 8010 13.129.107.213 35276 2018-02-18T15:36:15.4721718Z
2018-02-18 15:37:30.499 172.16.1.4 8010 13.129.107.213 35277 2018-02-18T15:36:15.4721718Z
2018-02-18 15:37:30.499 172.16.1.4 8010 13.129.107.213 35253 2018-02-18T15:36:15.4721718Z
Example of an expanded message/record:
Received by
NSG Flow Logs US EAST on  721931dd / USA1042LV000905
Stored in index
graylog_0
Routed into streams
All messages
@timestamp
2018-02-18T15:36:00.000Z
@version
1
NetworkSecurityGroup
USA1039-NSG-NORTHCENTRALUS-BASE
ResourceGroup
USA1039-VDC-NORTHCENTRALUS
Subscription
AZURE-SUBSCRIPTION-ID-REMOVED-HASS
Version
1
category
NetworkSecurityGroupFlowEvent
destIp
172.16.1.4
destPort
8010
mac
000D3A609738
message
operationName
NetworkSecurityGroupFlowEvents
protocol
T
records
{"resourceId":["","SUBSCRIPTIONS","AZURE-SUBSCRIPTION-ID-REMOVED-HASS)","RESOURCEGROUPS","USA1039-VDC-NORTHCENTRALUS","PROVIDERS","MICROSOFT.NETWORK","NETWORKSECURITYGROUPS","USA1039-NSG-NORTHCENTRALUS-BASE"],"operationName":"NetworkSecurityGroupFlowEvents","systemId":"AZURE-SYSTEM-ID-REMOVED-HASS","time":"2018-02-18T15:36:15.4721718Z","properties":{"Version":1,"flows":{"rule":"DefaultRule_AllowVnetInBound","flows":{"flowTuples":["1518968160","13.129.107.213","172.16.1.4","35270","8010","T","I","A"],"mac":"000D3A609738"}}},"category":"NetworkSecurityGroupFlowEvent"}
rule
source
testserver
srcIp
13.129.107.213
srcPort
35270
systemId
time
timestamp
2018-02-18T15:37:30.499Z
traffic
A
trafficflow
I
unixtimestamp
1518968160
Logstash.conf example:
input {
    azureblob
        storage_account_name => "STORAGE-ACCOUNT-NAME-REMOVED-HASS"
        storage_access_key => "STORAGE-ACCOUNT-KEY-REMOVED-HASS"
        container => "insights-logs-networksecuritygroupflowevent"
        registry_path => "data2/registry"
        registry_create_policy => "resume"
        codec => "json"
        file_head_bytes => 12
        file_tail_bytes => 2
        blob_list_page_size => 150
        interval => 5
    azureblob
        codec => "json"
        interval => 5
     azureblob
        codec => "json"
        interval => 5
filter {
     split { field => "[records]" }
     split { field => "[records][properties][flows]"}
     split { field => "[records][properties][flows][flows]"}
     split { field => "[records][properties][flows][flows][flowTuples]"}
mutate{
   split => { "[records][resourceId]" => "/"}
   add_field => {"Subscription" => "%{[records][resourceId][2]}"
                 "ResourceGroup" => "%{[records][resourceId][4]}"
                 "NetworkSecurityGroup" => "%{[records][resourceId][8]}"}
 split => { "[records][properties][flows][flows][flowTuples]" => ","}
   add_field => {
               "unixtimestamp" => "%{[records][properties][flows][flows][flowTuples][0]}"
               "srcIp" => "%{[records][properties][flows][flows][flowTuples][1]}"
               "destIp" => "%{[records][properties][flows][flows][flowTuples][2]}"
               "srcPort" => "%{[records][properties][flows][flows][flowTuples][3]}"
               "destPort" => "%{[records][properties][flows][flows][flowTuples][4]}"
               "protocol" => "%{[records][properties][flows][flows][flowTuples][5]}"
               "trafficflow" => "%{[records][properties][flows][flows][flowTuples][6]}"
               "traffic" => "%{[records][properties][flows][flows][flowTuples][7]}"
   add_field => {
                "time" => "%{[records][time]}"
                "systemId" => "%{[records][systemId]}"
                "category" => "%{[records][category]}"
                "operationName" => "%{[records][operationName]}"
                "Version" => "%{[records][properties][Version]}"
                "rule" => "%{[records][properties][flows][rule]}"
                "mac" => "%{[records][properties][flows][flows][mac]}"
   convert => {"unixtimestamp" => "integer"}
   convert => {"srcPort" => "integer"}
   convert => {"destPort" => "integer"}
  date{
    match => ["unixtimestamp" , "UNIX"]
output {
    udp {
        host => "172.18.4.10"
        port => 12201
What queries are you running against these messages? Please provide some examples.
Hi Jochen, it was just simple queries e.g…
destPort:8080
That said it now seems to be working if I clear everything from the search window, I’ll do some more testing over the next few days to make sure I’m not going crazy.
Thanks for the quick support
Hass
So maybe your queries are incorrect? That’s why I’ve asked for some sample queries. :wink:
yes I would suggest it must be user error, thing is I was testing this for a number of days before I gave in and logs the post…!
