Sidecar container failing to connect to graylog server
I have started graylog service with the help docker-compose file my graylog service is working fine I am able to access my graylog web interface . I wanted to send my application logs via sidecar So with the help of Dockerfile available for sidecar I started my sidecar conatiner.But my sidecar container unable to connect to graylog server
  • OS Information: Debian 10
  • Package Version:
    sidecar version - 1.0.1
    graylog-image -4.2
    level=error msg="[UpdateRegistration] Failed to report collector status to server: Put http://0.0.0.0:8007/api/sidecars/scorer: dial tcp 0.0.0.0:8007: connect: connection refused"
Please suggest if anything thing is missing in the configuration.
Should my sidecar container should in same network as that of graylog?
Disclaimer! I’m kinda new to Graylog, but I’ll give this a try. I had the same kind of problem today, so hopefully this helps.
This tells me that you got the wrong ip in your Collector configuration or in the sidecar.yml
In the sidecar configuration, if you have something like (or if this section is missing - add it)
output.logstash:
   hosts: ["0.0.0.0:8007"]
Change it to
output.logstash:
   hosts: ["<ip-to-logstash>:8007"]
If that checks out, check your sidecar.yml
Make sure that the first variable, on line three, points to your logstash server.
server_url:
Judging from the error , It a graylog sidecar configuration issue.
GL sidecar configuration file should be located here.
vi /etc/graylog/sidecar/sidecar.yml
Think you missing the URL for the Graylog instance.
server_url: "http://192.168.1.20:9000/api/"
Example of mine: Basic configuration.
root@keycloak:~# cat  /etc/graylog/sidecar/sidecar.yml | egrep -v "^\s*(#|$)"
server_api_token: "1sdjiu5d6bjp2u44qrbvtjc74r2b79epb8us9n4vlp2bugrsr885"
node_id: "file:/etc/graylog/sidecar/node-id"
node_name: "keycloak101"
update_interval: 10
tls_skip_verify: true
send_status: true
list_log_files:
    - "/var/log/"
root@keycloak:~#
I used this documentation here
