Show MB not Bytes
Hello All,
I’m very new to graylog. We have squid sending it’s logs to graylog and I have a dashboard showing our largest users. However, it shows in Bytes and I’d like to get it to show in MBytes. I am hoping there’s a very easy way for a newbie to be able to convert from one to the other.
The dashboard simply uses sum(Bytes) as the metric. What would be the easiest way to get this to show MBytes?
Thanks in advance.
currently math is not possible on this fields -
you might want to send a feature request over here: https://github.com/Graylog2/graylog2-server/issues
