Setting up email for alerts
having this issue, using gmail. Could it be that if I change to office365 it’d work?
my config:
transport_email_hostname = smtp.gmail.com
transport_email_port = 587
transport_email_use_auth = true
transport_email_use_tls = true
transport_email_auth_username = email
transport_email_auth_password = password
transport_email_from_email = graylog@example.com
My Error is: An error occurred while trying to send an email! (triggered 9 minutes ago)
The Graylog server encountered an error while trying to send an email. This is the detailed error message: org.apache.commons.mail.EmailException: Sending the email to the following server failed : smtp.gmail.com:587 (com.sun.mail.util.MailConnectException: Couldn’t connect to host, port: smtp.gmail.com, 587; timeout 60000; nested exception is: java.net.SocketTimeoutException: connect timed out)
Tried to telnet to smtp.gmail.com 587 but nothing
I don’t know if this will solve your issue but in “transport_email_from_email =”, I used the same address that is in “transport_email_auth_username =”.
Also is there any firewall that can block the outgoing traffic?
thanks for the response, I had changed that to the auth email but still nothing. I too think it might the firewall blocking outgoing traffic.
Try to test the destination port with a tool, no doubt after that.
nc -zv smtp.gmail.com 587
just search in this community - How to send email alerts using Gmail - should guide you.
Hey,
So, I’ve been speaking to my IT team because initially I believed we had to use the company’s mail server. So we have been working on that, but I am still getting error. This is the error we I am currently getting:
The Graylog server encountered an error while trying to send an email. This is the detailed error message: org.apache.commons.mail.EmailException: Sending the email to the following server failed : smtp.intra.COMPANY.local:25 (com.sun.mail.util.MailConnectException: Couldn’t connect to host, port: smtp.intra.COMPANY.local, 25; timeout 60000; nested exception is: java.net.UnknownHostException: smtp.intra.COMPANY.local)
Firewall is configured, and it worked at system level. I believe it could be on the application end. Does anybody have a clue of what it might be?
you should check if the name and port are correct:
Thanks for replying. Yes, it is correct.
something between the Graylog System (master) and the Mailserver then is blocking the access. That is the error message.
How could I go on about checking this?
As far as I know the graylog server to mail server connectivity is fine:
root@RSH-TEST-GRLOG:/etc/graylog/server# telnet IP 25
Trying IP...
Connected to IP.
Escape character is '^]'.
220 S-EXCH-HYB02.intra.COMPANY.local Microsoft ESMTP MAIL Service ready at Fri, 28 Sep 2018 11:20:43 +0100
Apparently, I just fixed that issue. It came back to this other issue:
The Graylog server encountered an error while trying to send an email. This is the detailed error message: org.apache.commons.mail.EmailException: Sending the email to the following server failed : IP:PORT (javax.mail.AuthenticationFailedException: 535 5.7.3 Authentication unsuccessful )
I have whitelisted everything necessary.
you provided the wrong user or password
the user and password is correct though.
that is something I can’t check - I only interpret the systems error message. You are the only person that can verify and solve this.
