I am using Graylog v3.2 and would like to enrich event notification with fields extracted from the original message. Assuming this could be done via Template option that used JMTE syntax, how is it possible to set a value using regular expressions? Official documentation has no examples nor does the JMTE syntax reference.
For example. ${source.messge} contains a string "custom_string='123'". To extract the value of custom_string we could use regex /custom_string='(.*)'/ and then select the second matching group.
Is this possible using the Template? Or there is a better way of doing it?
Thank you.
