Send old logs to graylog
We need to send old archive logs to graylog, from debian 11 with rsyslog
  • OS Information:
    Debian 11
  • Package Version:
    Graylog 5.2
The configuration i made in rsyslog.conf:
input(type="imfile"
      File="/var/logs/archive.log"
      Tag="log_old"
      Severity="info"
      Facility="local0"
      PersistStateInterval="20000"
      ReadMode="2"
      parseTimestamp="on")
if $programname == 'log_old' then {
    action(type="omfwd"
           Target="192.168.70.7"
           Port="515"
           Protocol="udp")
    stop
The log format example line is:
Jul 14 22:06:03 server-2 CRON[3152447]: (CRON) info (No MTA installed, discarding output)
The line arrives to graylog but not with the original timestamp, graylog put the current time to the event, i need the original timestamp of the log line.
Guidance to export a old log.
You could use an extractor to read the timestamp on the incoming data, and put the timestamp in the timestamp field of graylog.
Could be done with a pipeline processor to.
