Send logs from Cisco Firewall to Graylog
I’m looking for a way how to send only specific ID’s to Graylog server. I mean not all logs classified as warning, error or something, I just want to send a specific ID’s - for example if someone from inside trying to reach out any IP outside and one of my access list deny this request, the log ID is 106100.
  • OS Information: Cisco ASA, Graylog is installed on Ubuntu 22.04
  • Package Version: Graylog 5.0
  • Service logs, configurations, and environment variables: that is I’m looking for how to configure
Still nothing.
Advice.
As far as I remember ASA, you can decide up to which log-level you want to send logs. You can also change the log-level per ID if I remember correctly. With those both properties you can send logs to Graylog.
If you receive more in Graylog than you want you can delete Logs based on their ID:
  1. build a rule to extract the ID in a certain field, we call it asa_syslog_id
  2. create a rule if the field has a certain value to drop the message
Or, if your list of event, ideas is very short, you can build a rule that throws away any message that does not contain your specific IDs. Boolean operators in pipelines are very useful for this.
I think that my list is really short. My goal is to drop the logs on the source - Cisco. It’s not necessary to receive all logs to the Graylog server and drop it there - it will exhaust my SSD soon.
Hey @brkw
The suggestion that @ihe stated might help, for example you can set the Severity Levels for warning/critical etc… that may help to reduce the amount of logs your receiving.
You may be surprised. Dropping messages as soon as they arrive does not require much I/O.
