Send different input to the graylog using filebeats
I want to send 3 input to the graylog using filebeats, which are: auth.log, access.log, and error.log. and i want to differentiate them into 3 output in graylog, with 3 different port ( i have 1 server graylog). so i have 3 different input in graylog. i have tried this configuration but it doesnt appear any logs:
filebeat.yml
filebeat.inputs:
  - type: log
    enabled: true
    paths:
      - /path/auth.log
    fields:
      log_type: auth_logs
    fields_under_root: true
  - type: log
    enabled: true
    paths:
      - /path/access.log
    fields:
      log_type: access_logs
  - type: log
    enabled: true
    paths:
      - /path/error.log
    fields:
      log_type: error_logs
output:
  if:
    equals:
      log_type: "auth_logs"
  logstash:
    host: graylog_server_ip
    port: 12201
  else if:
    equals:
      log_type: "access_logs"
  logstash:
    port: 12202
  else if:
    equals:
      log_type: "error_logs"
  logstash:
    port: 12203
  else:
    logstash:
      port: 12204
in graylog inputs, i tried to used gelf tcp and beats but both not works. i think the problem is in the output, but i dont know how. please help
Beats is the input type you will want to use, by why are you wanting to send them in seperately, you can just use pipelines to route them once they are in graylog even on the same input?
i want to differentiate those logs (in the input graylog), so it would be clearer information. does using pipelines can separate the input logs in graylog?
Ya absolutly! The regular way to do it would be to send them all through one input, and then use a pipeline with route_to_stream and using the when section of the pipeline to filter the messages you want routed to that location.
Something like
When
$message.source == “8.8.8.8”
Then
Route_to_stream(name: “my stream”, remove_from_default: true);
End
But you can use any supported function in the when section to select the messages.
