Searching for msg="" in Graylog 4.3 but I also get msg="1" in resultset
I am searching for msg=”” occurrences in my log files using Graylog 4.3. I use message:msg=\”\” to do the search and escape the ““ as I think would be expected. But my result set doesn’t only return msg=”” but it also returns msg=”1” etc. It is almost as if I used msg=”*”. This is not the expected result and I am strictly looking for msg=””
  • OS Information: Rocky Linux 8.10
  • Package Version: Graylog 4.3
I have tried to use msg.keyword:”” instead of message:”msg=\”\””. I have also used full_message instead of message. But none get to my desired result.
Is there something I am missing? I would appreciate the community advice on this topic.
Hey @ofentselogger,
Understanding how searches work when using the message/full message field is important, Opensearch is performing tokenisation that you might not be aware of. This post goes some way to explaining that
The best approach would be to parse out the msg=value into it’s own field, this field could then be searched/aggregated and would not be tokenised.
I would also mention that Graylog 4.3 is very outdated and you should probably use a more recent version.
