charlie
(charlie)
1
I currently have microsoft IIS logs shipping into Graylog with extractors for each field. What I’m looking for is a way to search for something like:
source:iis-vm-abc AND _exists_c-ip AND NOT sc-status:a{200,399}
I’m basically look for:
Logs are from IIS abc
The public source IP exists
The sc-status isn’t a 200-399 response (I’m after 400 -> 599)
Any idea how I can regex the last bit?
Thanks!
jan
(Jan Doberstein)
2
It depends how you have seperated the information into single fields and if those fields are saved as number or string.
Number search would be easy ( http://docs.graylog.org/en/2.4/pages/queries.html#syntax ) and would be the prefered option.
What is your elasticsearch mapping for the fields you search in?
charlie
(charlie)
3
Thank you,
It’s a number field. my nxlog config is as follows:
I’ll take a look at the guide and see if I can get it to work
charlie
(charlie)
4
Perhaps I have it wrong? Current error:
Can only use regexp queries on keyword and text fields - not on [sc-status] which is of type [long]
