Ruby On Rails Content Pack
@lennartkoopmann
Download from Github
View on Github
Open Issues
Stargazers
Logging from a Ruby on Rails application to a Graylog server
This guide briefly describes the steps required to send logs from your Ruby on Rails application to a Graylog server. The Rails version used in this guide is v4.2.1. but should work with different versions, too.
Overview
We’ll be using the official Graylog GELF gem to transport messages formatted by the lograge gem. The reason to use lograge is that Rails has a default logger that is very noisy and splits up messages over multiple lines. Lograge does a great job taming the format and provides a key=value formatter that we can use to extract fields in Graylog later.
Configure Graylog
We provide a Graylog content pack that starts the correct GELF input type together with extractors (parser rules) to make the configuration really easy. Just apply this content pack using your Graylog Web Interface and follow the next steps in this guide.
Configuring your Rails application
Add the two gems to your Gemfile :
gem 'gelf'
gem 'lograge'
In your config/environment/development.rb (and production.rb ) set up Rails to log to your Graylog server:
config.logger = GELF::Logger.new("graylog.example.org", 12219, "WAN", { :facility => "YOUR_APP_NAME" })
You may need to manually include the silencer module to your GELF logger to avoid
NoMethodError (undefined method 'silence_logger' for #<GELF::Logger:0x0000000007f5f170>):GELF::Logger.send :include, ActiveRecord::SessionStore::Extension::LoggerSilencer config.logger = GELF::Logger.new(…)
This silencer is being used to silence the logger and not leaking private information into the log, and it is required for security reason.
Create a new initializer ( config/initializers/lograge.rb ) to configure the lograge formatting:
Rails.application.configure do
config.lograge.enabled = true
config.lograge.formatter = Lograge::Formatters::KeyValue.new
Your Rails application should now log into the Graylog input the content pack launched and already apply proper parsing of the message content into fields.
Custom events
The above steps forward the standard built-in Rails logs to Graylog in realtime. Any explicit call to logger will also be sending to Graylog, but without the lograge formatting applied:
logger.info("A new user with id <#{user.id}> signed up.")
