Routing Graylog Events into Another stream
I understand there is a stream called All events. I would like to route all graylog events that are alerts into another stream. I have tried creating the following pipeline rule but no messages have been coming through. The ‘remove matches from all messages stream’ is disabled for the All events stream too.
rule "Write: Alert Stream"
    has_field("alert")
    and contains(to_string($message.alert), "true")
    //route the message to the stream and index
    route_to_stream(name: "Alert Stream");
he @sunicod
you can’t do processing on the events stream as those messages are not processed like normal messages. You can’t move them out of that desired events stream.
Thank you for confirming.
