Graylog v2.5.1+34194da
I have a stream called auditd using index set auditd.
Pipeline processor is after Message Filter chain in the configuration
I have a pipeline rule with
route_to_stream(name: “auditd”, remove_from_default: true);
Message says it was routed to stream auditd but the message is stored in the default index so it is not searchable in the stream.
Stored in index
graylog2_511
Routed into streams
I would like the message to be routed to stream auditd and be searchable in the stream. Is this possible?
Thanks.
