Can you help me decipher the causes?
This is my current configuration
Operating system information
Ubuntu 20.04.3 virtual on Virtualbox version 6.1.28 with Guest Addictions and Extension Pack installed - 64Gb ram, 12 Processor and 600Gb of Virtual Disk Space
Ubuntu 20.04.3 phisical machine with 2 1TB HDD - RAID1 - 256 Gb ram
Package versions
Graylog 4.2.5
MongoDB 4.0.27
Elasticsearch 7.10.2
I use a single node configuration
server.conf
/# Frequency of the Elasticsearch node discovery.
/# Default: 30s
/# elasticsearch_discovery_frequency = 30s
and this is my index rotation
Index prefix:
graylog
Shards:
4
Replicas:
1
Field type refresh interval:
5 seconds
Index rotation strategy:
Index Time
Rotation period:
P1D (1 day, a day)
Index retention strategy:
Delete
Max number of indices:
35
Could the cause of these issues be the known CPU overuse issue resulting from the Java version following the upgrade of Graylog to versions 4.1.x after the Apache vulnerability mitigation?
but I can’t find any wording that reports as you reported
discovery.type: single-node
This is my default index setting
Default index set 35 indices, XXXXX documents, XXX GiB default
The Graylog default index set. Graylog will use this index set by default.
Index prefix: graylog
Shards: 4
Replicas: 1
Field type refresh interval: 5 seconds
Index rotation strategy: Index Time
Rotation period: P1D (1 day, a day)
Index retention strategy: Delete
Max number of indices: 35
Hello @alessio.dapelo
I’ll explain this a little better.
From the error I see above was what I’m referring to.
The use of discovery.type: single-node Stated here
So this document states:
We recognize that some users need to bind transport to an external interface for testing their usage of the transport client. For this situation, we provide the discovery type single-node (configure it by setting discovery.type to single-node); in this situation, a node will elect itself master and will not join a cluster with any other node.
Judging from the title of this post about the “error” message in questioned and you stated
Which I assume because of a misconfiguration, the error went away. Since the error is pointing to not_master_exception, reason=no longer master from this message below.
If this is a single node and as I stated before adding this line in your Elasticsearch YAML file. discovery.type: single-node
This type of configuration is shown in Elasticsearch documentation.
And I quote:
discovery.type:
(Static) Specifies whether Elasticsearch should form a multiple-node cluster. By default, Elasticsearch discovers other nodes when forming a cluster and allows other nodes to join the cluster later. If discovery.type is set to single-node, Elasticsearch forms a single-node cluster and suppresses the timeout set by cluster.publish.timeout. For more information about when you might use this setting, see Single-node discovery
