Remove_from_stream does not work
I have this strange behavior about remove_ffrom_stream function.
In my pipeline joined to Stream 1 I have
–STAGE 1
let x = clone_message();
set_field(“cloned”, true);
remove_from_Stream(name:“Stream1”, message x);
route_to_stream(name: “Stream2”, message x);
As i want that the cloned message goes to another stream.
But the cloned message is visible as in the Stream1 as in the Stream2.
Why? Is this a bug or is it something I’m doing wrong?
Gianluca
I solved changing the rule where condition and adding an additional rule stage
