I am trying to migrate graylog to a new version. Currently I have the elasticsearch indexes in version 1.7, I can read them from elasticsearch 2.x but I need to reindex to be able to read them in versions 5.x or higher.
For this I am trying to use the reindexing API, but I am getting the following error several times:
“index”: “graylog_2023_re”,
“type”: “message”,
“id”: “f27395d1-92d6-11eb-9a08-525400f612cd”,
“cause”: {
“type”: “mapper_parsing_exception”,
“reason”: “Field [_id] is a metadata field and cannot be added inside a document. Use the index API request parameters.”
“status”: 400
I don’t know about you, but I think the better way to do this is via Kibana, I’m not a big fan of UI in general to administrate things, but normally Kibana is pretty handy hepling execute internal stuf in ES.
I’m very sorry for losting your time, but what I said in last comment was made without confirm if it’s possible to be done via Kibana, apparently it isn’t.
However, I saw in this link that you can fix this error following this step:
Message 1: “org.elasticsearch.index.mapper.MapperParsingException: Field [_id] is a metadata field and cannot be added inside a document. Use the index API request parameters”
The document source to index contains a field called “_id” which is reserved as metadata inside Elasticsearch. According to Elasticsearch documentation, each document has metadata associated with it, such as the _index , mapping _type , and _id metadata fields. Here is a complete list of metadata fields in Elasticsearch 7.9:
It looks like it’s because of the ID field, but I don’t really know how to replace it with the scripts I’ve found.
I will ask in the elastic forums, maybe they can give me a possible solution.
Again, thank you very much, greetings.
