Regex is killing me
I’m trying to enrich a bunch of windows sysmon logs. The ultimate goal is to set a field on processes launched from an office application. I.e. if Word launches Powershell or an unknown process, I want to know about it.
I know Java regex seems a bit pickier than others, but here is where I’m at. Here are some samples from of sysmon logs.
explorer.exe
C:\WINDOWS\system32\WerFault.exe -u -p 137120 -s 4024
C:\WINDOWS\system32\WerFault.exe -pss -s 792 -p 137120 -ip 137120
"C:\Program Files (x86)\Adobe\Acrobat 2017\Acrobat\AcroCEF\AcroCEF.exe" --backgroundcolor=5066061
C:\Program Files (x86)\Adobe\Reader DC\AcroRd32.exe
I want to filter out noise from Adobe products (and note the occasional double-quote at the start).
(?i)(c:\\program files \(x86\)\\adobe).*$
This works in both https://regex101.com/r/BYUqJO/1/ and https://www.freeformatter.com/java-regex-tester.html#ad-output
However, the moment I try to use it in my pipeline, the editor cries about it. Not to mention, I can’t get an optional capture group around the (x86) working either. To me, it should be ( \(x86\))?
rule "Threat Intel - Sysmon Parent Process"
    (has_field("parent_command") OR has_field("parent_process")) AND
    (regex("(?i)(acrobat|winword|excel|lync|powerpnt|acrord32|notepad|calc)", to_string($message.parent_command)).matches == true OR
    regex("(?i)(acrobat|winword|excel|lync|powerpnt|acrord32|notepad|calc)", to_string($message.parent_process)).matches == true) AND
    (to_string($message.command) != "C:\\WINDOWS\\splwow64.exe 8192" AND
    regex("(?i)(c:\\program files \(x86\)\\adobe).*$",to_string($message.command)).matches != true)
set_field("suspicious_parent",to_bool("true"));
Any pointers? Where have I bunged this up, aside from being a total rookie with regex.
I believe your optional x86 requires the space inside the paren section as follows:
( \(x86\))?
See: https://regexr.com/3f4vo
I have the space in tests
Your regex should work, but looks like it might be a bug in Graylog - It didn’t like the ( and x combo.
Try the below, seems to match your samples & requirements. Note I added an optional line which might be simpler for you, “starts_with”
    ( has_field("parent_command") OR
    ) AND (
    ) AND (
        starts_with(to_string($message.command), "c:\\program files (x86)\\adobe", true) AND
        regex("(?i)(c:\\program Files(\s(.*?))?)\\adobe",to_string($message.command)).matches != true
Thanks @lindonm
I’m trying to use your code and I’m getting ‘Invalid Expression’ error Line 3, Column 4 and I can’t find the typo myself. :confused:
did you double escape the escapes?
java Regex make it really hard sometimes, I personal try to check in https://www.freeformatter.com/java-regex-tester.html
But the double escape the escapes usually makes the trick
Can you give an example?
I can’t make the same sample work with either two or three escapes.
Actually the error was on the program files regex line sorry - Try this, i’m not sure if it will actually match for you though it does allow me to save it now (added double escapes as per Jan’s comment)
regex("(?i)(c:\\\\program Files(\\s(.*?))?)\\\\adobe",to_string($message.command)).matches != true
That did it! Thanks @lindonm
Now that I know I need 4 slashes to replace one…
So, by that logic, do I need 8 slashes for a Windows UNC? \\Serverlocation\Folder\File.exe ? That seems pretty intense.
I can only assume so, try it out and let us know :slight_smile:
