Regarding Graylog stream
Hi would like to know, if I have already ingest my log to graylog and it have moved to stream A. However if, I would like to move the log from Stream A to Stream B, will it be possible?
Below will be my example. The current log is in my filebeat_test_stream. If I would like to move to a stream name name “Android” will that be possible?
No currently you cannot change any message fields in Graylog after they arrive, and the stream is technically just a message field.
