Regarding dashboard inquiry and consultation
Hello。
I want to know about this What device is JUN, as other devices have IP addresses or names, which is quite confusing.
I would say: filter for that and have a look at the log.
From my experience I would say this might be some syslog which is a bit broken.
You can try to add the field “gl2_remote_ip” in your “All Messages” widget and see, who is shipping this strange logs.
From my experience its most likely a Cisco IOS device, depending on their settings they dont follow proper syslog format. Do what @ihe described to find which one, snd then you would probably need to change settings on the device.
I tried the method he said, and it was indeed generated by Cisco equipment. @ihe
Cisco is well known for that. Across all their devices, firewalls, switches, routers, … :melting_face:
Hahaha, do you have any suggestions about this? After all, they are all Cisco devices
for those devices create an extra input and make it as a “TCP RAW” or “UDP RAW”. You might have some glibberish start of the message, but after the header it should be like syslog
