How can i integrate MS SQL 2008 R2 in graylog to receive log data?
thanks in advance.
best regards.
thanks in advance.
best regards.
How is Microsoft SQL Server 2008 R2 emitting its logs?
If it’s using the standard Windows Event Log facilities, you can use Winlogbeat (which is also supported by the Graylog Collector Sidecar) to collect these log messages and send them to Graylog.
