Questions: Why hourly cpu peaks ?
Hello, I have 5 graylogs servers running on virtual machines on different hypervisors. Each Graylog have a single Input defined and receive logs without stop. Server will have a cpu peak every hour, coming from a ~5% cpu usage and peaking to ~25/35% cpu usage:
The VMs have these specs:
Debian 10 64bits
6 CPU / 8G RAM
MongoDB standalone 4.2.17
Single node Elasticsearch-OSS 7.10.2 (-Xms2g -Xmx2g)
Graylog 4.1.7 using these importants parameters:
rotation_strategy=time
elasticsearch_max_time_per_index=1d
elasticsearch_max_docs_per_index=20000000
retention_strategy=delete
elasticsearch_shards=1
I’m wondering why is there those hourly CPU peaks, what could be done to not have thoses (or a least decrease their intensity), and if there is some maintenance option/configuration that could be changed related to this ?
Thanks for reading.
Need to ask a couple questions.
  • I’m assuming those configurations are in graylog configuration file?
  • Then under System/Indices does it show the same settings?
  • Have you checked or Tailed you log files ( i.e. Elasticsearch and Graylog) when this occurs?
  • Did you use TOP and/or HTOP and monitor when this happens? you should see what using so much CPU.
  • Do you have Elasticsearch and Graylog on the same node?
