Question: Okta Logs
Cant find any documentation about uploading Okta API logs to Graylog.
  • OS Information:
    Ubuntu on EC2, 50 GiB, 4 vCPU
    Graylog v5.1
followed this guide with no success:
What should be done to create the integration?
What is the volume of data you need to ingest in total? The enterprise version of Graylog (including the free 2GB license) has a built in okta input that is dirt simple to setup. Okta Log Events Input
I dont have the enterprise version, unfortunately.
I will need to save 6 months of logs… I guess it’s at least 50 GB. Not sure.
50gb a day, or 50 gb for 6 months?
6 month
I would also say that I have made a script to use the Okta API and save the logs to a JSON file, but could not understand what to do next
So if your under 60GB over 30 days, specifically 2gb a day, you could use the free enterprise version and just use the enteprise input.
If not and your script saves to a text file, then use filebeat to read that into graylog, and then the parse_json and flatten_json functions in pipelines to parse the json.
