Purge logs according to timestamp
I am trying to wipe some logs from one of my graylog indices using curl. When I execute get I get all my logs, but when trying to delete them I get “found”:false
Here’s my get:
curl -XGET "http://graylog.example.com:9200/graylog_index/message/_search" -d '
  "query" : {
    "range" : {
        "timestamp" : { "gte" : "2017-07-27 00:00:00.000", "lt" : "2017-07-29 00:00:00.000||+1M"}
and it is working, but substituting -XGET with -XDELETE and _search with query is returning the following:
{"found":false,"_index":"graylog_index","_type":"message","_id":"_query","_version":1,"_shards":{"total":1,"successful":1,"failed":0}}
Thanks in advance.
You need to install the Delete by Query plugin if you want to delete documents from Elasticsearch defined by a query.
