Hello!
After reading upgrade path to 6.0.x, I installed the latest version of graylog-server (6.0.2-1), but it doesn’t want to start
Here is what says logs:
2024-05-27T12:34:28.879+05:00 ERROR [DbEntitiesCatalog] Two model classes associated with the same mongo collection : DbEntityCatalogEntry[collection=nodes, titleField=node_id, modelClass=class org.graylog2.cluster.nodes.ServerNodeEntity, readPermission=__no_access__] and DbEntityCatalogEntry[collection=nodes, titleField=node_id, modelClass=class org.graylog2.cluster.NodeImpl, readPermission=__no_access__]
2024-05-27T12:34:29.200+05:00 ERROR [CmdLineTool] Guice error (more detail on log level debug): java.lang.IllegalStateException: Two model classes associated with the same mongo collection : DbEntityCatalogEntry[collection=nodes, titleField=node_id, modelClass=class org.graylog2.cluster.nodes.ServerNodeEntity, readPermission=__no_access__] and DbEntityCatalogEntry[collection=nodes, titleField=node_id, modelClass=class org.graylog2.cluster.NodeImpl, readPermission=__no_access__]
2024-05-27T12:34:29.200+05:00 ERROR [CmdLineTool] Startup error:
com.google.inject.CreationException: Unable to create injector, see the following errors:
1) [Guice/ErrorInCustomProvider]: IllegalStateException: Two model classes associated with the same mongo collection : DbEntityCatalogEntry[collection=nodes, titleField=node_id, modelClass=class ServerNodeEntity, readPermission=__no_access__] and DbEntityCatalogEntry[collection=nodes, titleField=node_id, modelClass=class NodeImpl, readPermission=__no_access__]
while locating DbEntitiesScanner
at MongoDBModule.configure(MongoDBModule.java:29)
while locating DbEntitiesCatalog
Learn more:
https://github.com/google/guice/wiki/ERROR_IN_CUSTOM_PROVIDER
1 error
Full classname legend:
DbEntitiesCatalog: "org.graylog2.database.dbcatalog.DbEntitiesCatalog"
DbEntitiesScanner: "org.graylog2.database.dbcatalog.DbEntitiesScanner"
MongoDBModule: "org.graylog2.bindings.MongoDBModule"
NodeImpl: "org.graylog2.cluster.NodeImpl"
ServerNodeEntity: "org.graylog2.cluster.nodes.ServerNodeEntity"
End of classname legend:
at com.google.inject.internal.Errors.throwCreationExceptionIfErrorsExist(Errors.java:589) ~[graylog.jar:?]
at com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:190) ~[graylog.jar:?]
at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:113) ~[graylog.jar:?]
at com.google.inject.Guice.createInjector(Guice.java:87) ~[graylog.jar:?]
at org.graylog2.shared.bindings.GuiceInjectorHolder.createInjector(GuiceInjectorHolder.java:34) ~[graylog.jar:?]
at org.graylog2.bootstrap.CmdLineTool.setupInjector(CmdLineTool.java:530) ~[graylog.jar:?]
at org.graylog2.bootstrap.CmdLineTool.doRun(CmdLineTool.java:317) ~[graylog.jar:?]
at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:267) [graylog.jar:?]
at org.graylog2.bootstrap.Main.main(Main.java:55) [graylog.jar:?]
Caused by: java.lang.IllegalStateException: Two model classes associated with the same mongo collection : DbEntityCatalogEntry[collection=nodes, titleField=node_id, modelClass=class org.graylog2.cluster.nodes.ServerNodeEntity, readPermission=__no_access__] and DbEntityCatalogEntry[collection=nodes, titleField=node_id, modelClass=class org.graylog2.cluster.NodeImpl, readPermission=__no_access__]
at org.graylog2.database.dbcatalog.DbEntitiesCatalog.add(DbEntitiesCatalog.java:46) ~[graylog.jar:?]
at java.base/java.lang.Iterable.forEach(Unknown Source) ~[?:?]
at org.graylog2.database.dbcatalog.DbEntitiesCatalog.<init>(DbEntitiesCatalog.java:38) ~[graylog.jar:?]
at org.graylog2.database.dbcatalog.impl.ClassGraphDbEntitiesScanningMethod.scan(ClassGraphDbEntitiesScanningMethod.java:70) ~[graylog.jar:?]
at org.graylog2.database.dbcatalog.DbEntitiesScanner.get(DbEntitiesScanner.java:55) ~[graylog.jar:?]
at org.graylog2.database.dbcatalog.DbEntitiesScanner.get(DbEntitiesScanner.java:29) ~[graylog.jar:?]
at com.google.inject.internal.ProviderInternalFactory.provision(ProviderInternalFactory.java:86) ~[graylog.jar:?]
at com.google.inject.internal.BoundProviderFactory.provision(BoundProviderFactory.java:72) ~[graylog.jar:?]
at com.google.inject.internal.ProviderInternalFactory.circularGet(ProviderInternalFactory.java:60) ~[graylog.jar:?]
at com.google.inject.internal.BoundProviderFactory.get(BoundProviderFactory.java:59) ~[graylog.jar:?]
at com.google.inject.internal.ProviderToInternalFactoryAdapter.get(ProviderToInternalFactoryAdapter.java:40) ~[graylog.jar:?]
at com.google.inject.internal.SingletonScope$1.get(SingletonScope.java:169) ~[graylog.jar:?]
at com.google.inject.internal.InternalFactoryToProviderAdapter.get(InternalFactoryToProviderAdapter.java:45) ~[graylog.jar:?]
at com.google.inject.internal.InternalInjectorCreator.loadEagerSingletons(InternalInjectorCreator.java:213) ~[graylog.jar:?]
at com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:186) ~[graylog.jar:?]
... 7 more
System info:
CentOS 7 (kernel 3.10)
Graylog Open: 5.2.5
Elasticsearch: 7.10.2-1
MongoDB: 6.0.12-1
What steps have you already taken to try and solve the problem?
I added ignore_migration_failures = true
to the server.conf file but it didn’t help
So what is the problem here and how can I fix it?
