Problem with graylog debian APT repository
I wrote
deb https://packages.graylog2.org/repo/debian/ stable 6.0
in /etc/apt/sources.list.d/graylog.list as the documentation states.
When I run apt update I can see it tries to reach https://graylog-package-repository.s3.eu-west-1.amazonaws.com/ which is blocked in my environment because I only allowed graylog2.org.
W: Failed to fetch https://packages.graylog2.org/repo/debian/dists/stable/InRelease  Invalid response from proxy: HTTP/1.1 407 Proxy Authorization Required
Is https://packages.graylog2.org/repo/debian/ still the correct url?
This seems to be the issue. If you’re blocking this URL you won’t be able to download graylog. You’ll need to either block this URL or download the install manually via Graylog Package Repository
Yes
