PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
after SSL setup on our Graylog server, I can login into Graylog and the browser is satisfied with the certificate. Right after login into Graylog via SSL, the following errors start to apear in /var/log/graylog/server.log:
After logout, the error messages stop filling the logfile.
Also: I can define an input (Syslog UDP) in the menu System > Inputs, but I can’t start it.
There are no errors and the input starts fine if TLS is disabled in server.conf
  • OS Information: AlmaLinux release 8.7 (Stone Smilodon)
  • Package Version: 5.0.6
2023-05-19T13:41:11.394+02:00 WARN [ProxiedResource] Unable to call https://syslog2.izum.pri:9000/api/system/metrics/multiple on node : PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
http_enable_tls = true
http_tls_cert_file = /etc/pki/tls/certs/graylog-certificate.pem
http_tls_key_file = /etc/pki/tls/private/graylog-key.pem
http_tls_key_password = XXXX
I have checked similar posts in the community without success.
Thanks for your suggestions,
Miloš
You’re in luck. @drewmiranda-gl just published a blog that gives excellent step by step guidance on how to enable TLS with Graylog. I encourage you to review it and come back with any questions you may have.
I could of used that like 7 years ago :laughing:
Thanks for the guide. It helped.
I suggest to integrate it in the installation manual, esecially the parts where the removal of text from the certificate and the import of public certs into Java Keystore are described.
Regards,
Miloš
Thanks @milos. It’s a good problem to have, but we are victims of our own success at the moment. Our docs team is working furiously to capture all the content that is being created throughout the company. These papers, videos, and such are meant to fill the gaps while they get caught up.
I’m glad it helped. @drewmiranda-gl will be pleased to hear it as well.
