Hi All,
I am facing issue with pipeline and regex, in my regex i have special character [, to escape this I am using \\[, you can see the complete regex below, while doing pipeline simulator getting extra \ in results, any idea how to avoid this ?
Pipeline
rule "file categorize"
has_field("message")
set_field("pipeline", "message");
let message_field = to_string($message.message);
//set_field("xy", key_value(message_field));
set_field("Pal_Inputs", regex("inputs=(\\\\[(.*?)\\\\])", to_string(message_field), ["rayees"]));
//set_fields(fields: key_value(value: "pipeline"));
set_field("pipeline2", to_string($message.transaction_date));
Message
2016-09-29 00:55:24,261 level=INFO tag="run_pal_workflow.py" msg="Run complete for appname=locationJoiner, job_date=20160912, status=Passed starttime=Thu Sep 29 00:10:31 2016, endtime=Thu Sep 29 00:55:19 2016, duration=0:44:47, inputs=[{"path": "/processed/pal/parse//staticDataJoin/latest", "tag": "static", "stats": {"size": "6.59GB"}}, {"path": "/processed/pal/parse/location/date=20160909", "tag": "location", "stats": {"size": "216.78GB"}}], outputs=[{"path": "/processed/pal/parse//test/locationStaticDataJoin", "tag": "locationstaticjoiner.output.path", "stats": {"diffSize": "45.96GB", "newFiles": ["/processed/pal/parse/test/locationStaticDataJoin/date=20160909"], "endSize": "218.80GB", "startSize": "172.84GB"}}]"
Result
{"1":"{\"path\": \"/processed/pal/parse//staticDataJoin/latest\", \"tag\": \"static\", \"stats\": {\"size\": \"6.59GB\"}}, {\"path\": \"/processed/pal/parse/location/date=20160909\", \"tag\": \"location\", \"stats\": {\"size\": \"216.78GB\"}}","rayees":"[{\"path\": \"/processed/pal/parse//staticDataJoin/latest\", \"tag\": \"static\", \"stats\": {\"size\": \"6.59GB\"}}, {\"path\": \"/processed/pal/parse/location/date=20160909\", \"tag\": \"location\", \"stats\": {\"size\": \"216.78GB\"}}]"}
