Pipeline whitespace issues
I have set up the following rule in a pipeline:
rule "Fortinet parsing"
    has_field("message")
    // extract all key-value from "message" and prefix it with kv_
    set_fields(
                fields:
                        key_value(
                            trim_value_chars: "\""
    route_to_stream(id:"........", remove_from_default:true);
but when it comes to values that have whitespace they get cut off, like this:
I tried delimiter but its not working:
key_value(
trim_value_chars: “”",
trim_key_chars:""", delimiters:" “,
kv_delimiters:”=") );
How can I get it to ignore the whitespace if it’s part of a value?
Thank you
I think, it’s a known problem with key_value pipeline function.
Try to use extractor key=value, it should work fine also with spaces:
