i am 3 days into graylog so be kind-
in a pipeline rule i am trying to create a field and set a value to a string
for example:
set_field(“env”, “MyString”);
does not work… i am missing some trickery here ?
note: “MyString” is not part of a message its simply a value i want to add on a condition.
Ponet
(Jesse Hills)
August 9, 2019, 12:57pm
2
Please provide the full rule as an example.
Sure.
rule “myrule”
true
set_field(“myfield”, “mystring”);
I expect a new field “myfield” with a string value of “mystring” inside…
Many thanks
Ponet
(Jesse Hills)
August 13, 2019, 2:46pm
4
set_field(“myfield”, “mystring”); is definitely correct syntax.
Are you sure that this rule is being run against messages?
All of my rules have a proper conditional check within the when section so, unsure about that in yours.
yeah i merely added “true” as an example. but for sure even the example does not work for me in 3.0.2 (no field created)…
I will go back and mess around again, but i am pretty sure this wasnt working.
Ponet
(Jesse Hills)
August 13, 2019, 2:55pm
6
How have you got your processing configured?
System > Configurations > Message Processors Configuration
I believe the processor order is correct because if i set the following it works
rule “myrule”
true
set_field(“myfield”, true );
Ponet
(Jesse Hills)
August 13, 2019, 3:00pm
8
Ah, maybe you are running into a mapping error within ES…
Maybe your ES is expecting the ‘myfield’ field to store a Boolean datatype so, when GL is attempting to write in a String value, ES is giving an error.
Maybe check your ES logs and check field mappings in your ES cluster…
