Pipeline rule processing unterstanding
I’m mildly confused on how rules in a stage processed. Are they run in parallel or sequential?
I tried the following:
Stage 1
Rule A - Should match a message if it has one of the Event IDs
rule "check_active_directory_event_id_range"
    has_field("winlogbeat_winlog_event_id") &&
        to_string($message.winlogbeat_winlog_event_id) == "1234" ||
        to_string($message.winlogbeat_winlog_event_id) == "2345" ||
        to_string($message.winlogbeat_winlog_event_id) == "3456" ||
        to_string($message.winlogbeat_winlog_event_id) == "4567"
Rule B - Should drop the message if the message does not match
rule "drop_unwanted_messages"
    true
    drop_message();
  1. All messages are dropped, but i can see the debug message in server logs - so i guess all rules are applied in the stage to all messages?
  2. How do i set “Continue processing on next stage when” to get matched messages from Rule A do be processed in Stage 2? F.e. to filter for another event_data field out of the filtered event ids?
Order of rules inside a stage are not guaranteed, if you need order you need multiple stages.
You sometimes want a rule in a stage and all it does is match but takes no action just to act as a filter of messages continue to the next stage.
