Pipeline Rule not working as expected
Hi there,
in relation to this thread: Pipeline Grok Patterns, I want to parse ASA messages for different Grok Pattern.
Now I have something like this:
rule "asa"
    has_field("message")
    let message_field = to_string($message.message);
    let asa0 = grok(pattern: "%{CISCOFW104001}", value: message_field, only_named_captures: true);
    let asa0 = grok(pattern: "%{CISCOFW104002}", value: message_field, only_named_captures: true);
    let asa0 = grok(pattern: "%{CISCOFW104003}", value: message_field, only_named_captures: true);
    let asa0 = grok(pattern: "%{CISCOFW104004}", value: message_field, only_named_captures: true);
    let asa0 = grok(pattern: "%{CISCOFW105003}", value: message_field, only_named_captures: true);
    let asa0 = grok(pattern: "%{CISCOFW105004}", value: message_field, only_named_captures: true);
    let asa0 = grok(pattern: "%{CISCOFW105005}", value: message_field, only_named_captures: true);
    let asa0 = grok(pattern: "%{CISCOFW105008}", value: message_field, only_named_captures: true);
    let asa0 = grok(pattern: "%{CISCOFW105009}", value: message_field, only_named_captures: true);
    let asa0 = grok(pattern: "%{CISCOFW106001}", value: message_field, only_named_captures: true);
    let asa0 = grok(pattern: "%{CISCOFW106006_106007_106010}", value: message_field, only_named_captures: true);
    let asa0 = grok(pattern: "%{CISCOFW106014}", value: message_field, only_named_captures: true);
    let asa0 = grok(pattern: "%{CISCOFW106015}", value: message_field, only_named_captures: true);
    let asa0 = grok(pattern: "%{CISCOFW106021}", value: message_field, only_named_captures: true);
    let asa0 = grok(pattern: "%{CISCOFW106023}", value: message_field, only_named_captures: true);
    let asa0 = grok(pattern: "%{CISCOFW106100_2_3}", value: message_field, only_named_captures: true);
    let asa0 = grok(pattern: "%{CISCOFW106100}", value: message_field, only_named_captures: true);
    let asa0 = grok(pattern: "%{CISCOFW419002}", value: message_field, only_named_captures: true);
    set_fields(asa0);
The problem is, when using more than 1 grok, that always only the last Grok is working as expected. What could be the issue?
Looks like you overwrite asa0 each time you let something equal it. For this to work, you would have to set_fields() each time you let asa0 equal something.
Thanks, now it´s working…
