Pipeline Rule not firing
Hi Folks,
I have created a pipe line rule
rule "Drop4624MachineAccounts"
	((to_string($message.EventID) == "4624"))
	AND
	(contains(to_string($message.TargetUserName),to_string("$"),true))
	drop_message();
I am using gelf to ingest windows security log.
I would like to drop specific events, in this case event 4624 whenever TargetUserName field contains a compyter account, A computer account has $ symbol at the end like
PC01$
I have tried using the contain function but it’s not working.
appreciate your assistance in making this work.
what kind of symbol did you look for? You might want to use proper formatting in the forum to make it more clear …
Hi Jan, I have updated the format. Some how the $ symbol went missing without formatting. Sorry for the inconvenience caused.
you want to escape the $ that should work - but not sure about as I do not have something to test with.
I have updated the Pipeline rule, however i still see events with computername
	AND
	(contains(to_string($message.TargetUserName),"/$",true))
	drop_message();
you escape a character with a \ and not a /
2018-09-17%2016_26_37-Graylog%20-%20Pipeline%20rule%20Drop4624MachineAccounts
upon using \ i am seeing syntax error. I tried without " but still, i got syntax error
did you tried a double \\? that might needed. But this is just guessing - not knowledge.
It might be easier to build a regex on this and not using contains.
Hi jan, i have earlier tried \\$ but that didn’t work either.
Can you share a sample pipeline rule that uses regex function and i will modify it to the need.
Hi Jan,
this is what worked for me. Thanks for you assistance in getting this sorted out.
//    (has_field("EventID") AND (to_string($message.EventID) == "4624"))
// Original - Now Commented
	(has_field("EventID") AND (to_string($message.EventID) == "4624")) AND to_bool(regex("([a-zA-Z0-9])+\\$",to_string($message.TargetUserName)).matches)
	drop_message();
