Pipeline Rule: Issues with key_value function (fields can be created in Simulator, but not in real time)
When using the rule simulator, the fields get set, when a log is being processed, the fields don’t get created, even though it’s the same message text.
  • OS Information:
    Ubuntu 20.04
  • Package Version:
    Graylog 5.2.10
    Here is an example of a log file that should be processed:
2024-09-05 09:14:13,807: username=yddasdasda, status=Failed Login, ipAddress=192.168.2.140, entryPoint=Universal API
Here is my pipeline rule:
rule "Jamf access log"
    has_field("message") &&
    $message.source == "jamf"
    let messageText = to_string($message.message);
    debug(concat("Original message: ", messageText));
    let pattern = "%{TIMESTAMP_ISO8601:timestamp}:%{GREEDYDATA}";
    let value_array = grok(pattern, messageText);
    let timestamp = value_array["timestamp"];
    let timestamp_string = concat(to_string(timestamp), ":");
    set_field("jamf_access_log_timestamp", timestamp);
    debug(concat("Extracted timestamp: ", to_string(timestamp)));
    let message_for_key_value_map = regex_replace("\\Q" + timestamp_string + "\\E",messageText,"",false);
    //debug(concat("Message after removing timestamp: ", message_for_key_value_map));
    let key_value_pairs = key_value(
        value: to_string(message_for_key_value_map),
        trim_key_chars: " ",
        trim_value_chars: " ",
        delimiters: ",",
        kv_delimiters: ":"
    debug(concat("Key-value pairs: ", to_string(key_value_pairs)));
    let entryPoint = key_value_pairs["entryPoint"];
    let ipAddress = key_value_pairs["ipAddress"];
    let jamf_status = key_value_pairs["status"];
    let username = key_value_pairs["username"];
    debug(concat("EntryPoint: ", to_string(entryPoint)));
    debug(concat("IPAddress: ", to_string(ipAddress)));
    debug(concat("Status: ", to_string(jamf_status)));
    debug(concat("Username: ", to_string(username)));
    set_field("jamf_entryPoint", entryPoint);
    set_field("jamf_username", username);
    set_field("jamf_ip_address", ipAddress);
    let geo = lookup("geoip", to_string(ipAddress));
    set_field("jamf_ip_address_geolocation", geo["country"].iso_code);
    set_field("jamf_access_log_status", jamf_status);
When trying the rule in the pipeline rule simulator, the logs look like this:
2024-09-05T12:19:48.665+02:00 INFO [Function] PIPELINE DEBUG: Key-value pairs: {username=yddasdasda, status=Failed Login, ipAddress=192.168.2.140, entryPoint=Universal API}
2024-09-05T12:19:48.665+02:00 INFO [Function] PIPELINE DEBUG: EntryPoint: Universal API
2024-09-05T12:19:48.665+02:00 INFO [Function] PIPELINE DEBUG: IPAddress: 192.168.2.140
2024-09-05T12:19:48.665+02:00 INFO [Function] PIPELINE DEBUG: Status: Failed Login
2024-09-05T12:19:48.665+02:00 INFO [Function] PIPELINE DEBUG: Username: yddasdasda
When an actual log message is being processed:
2024-09-05T10:38:24.186+02:00 INFO [Function] PIPELINE DEBUG: username=dfsafasdasdasfrahda, status=Failed Login, ipAddress=192.168.2.140, entryPoint=Universal API
2024-09-05T10:38:24.187+02:00 INFO [Function] PIPELINE DEBUG: {}
I tried using the debug log, giving me the desired values in the rule simulator, but not with the actual logs being processed, although the messages are the same.
Any help or tips would be appreciated. Also if any additional information is needed, please let me know.
Thanks & best regards
Hey @bettels-uhi,
Should the kv_delimiters be ‘=’ and not ‘:’?
set_fields(
   fields:key_value(
   delimiters:",",
   kv_delimiters:"="
