Hello
I am trying to determine which method would use less resources (cpu, load, memory, io) and load on the graylog cluster when extracting key values from a message, pipeline processor or extractor
to provide an example, approximately 20% of messages coming into an apache log input contain an URL string that we would like to parse that contain URL-encoded characters
GET /uri/rr.php?url=https%3A%2F%2Fwww.exampledomain.com/ar/%2Far%2Fconverter%2Fconvert%2F%3Ffield%3D1%26From%3DFIELD%26To%3DSAR&pageId=blank_convert&fromThisy=fieldExample&toThis=anotherFieldExample HTTP/1.1
With a pipeline processor, it would require at least two rules, the first would have regex to identify the message to be processed, and the other to grab certain key values and place in new fields.
With an extractor, this would be performed on the input following similar logic, only process messages containing a certain string.
What I would like to understand, is which method would require less resources on Graylog.
thanks
