Pipeline only work on "all messages" stream
pipeline only works on “all messages” stream but not on other streams. What could be the reason?
I have a simple one stage pipeline with only one simple rule as following
rule "pipeline tester"
    true
    rename_field(old_field:"source", new_field:"origin");
When I connect this pipeline to all message it works but when I connect it to the new stream I’ve created it stops working and throughput remains 0.
what am I missing?
the field source is mandatory, if the pipeline did not work, you might have entries in your server.log.
yes, it create a new field with the new name and the source field stays intact.
I’ll double check.
