Pipeline grok pattern UPPER CASE processing vars
i have created an pipeline rule to parse the custom apache logs
rule "apache smsat"
 has_field("message")
  // grok the message field
  let message_field = to_string($message.message);
  let parsed_fields = grok(pattern: "%{HOSTNAME:requestdomain} %{COMBINEDAPACHELOG}", value: message_field);
  set_fields(parsed_fields);
but the created fields also contain the processing field names like
BASE10NUM COMBINEDAPACHELOG COMMONAPACHELOG HOUR INT IP IPV4 MINUTE MONTH MONTHDAY QUOTEDSTRING SECOND TIME USER USERNAME YEAR
what am i doing wrong or how to get rid of these
You have to tell the grok() function to only use named captures.
