Pipeline does'n work
Hello!
  1. I use Graylog v3.3.9+abab7dc
  2. I created GELF-HTTP Input.
  3. I added stream for this input.
  4. I created pipeline for new stream.
  5. I added simple rule
    rule “Add date fields”
    true
    set_field(“let_1”, “1”);
  6. There is no new field (“let_1”) in new stream’s messages.
  7. “Pipeline Processor” is enabled.
Could you help me?
Plese be more verbose, especialy how did you configure stream connection for pipeline:
https://docs.graylog.org/en/4.0/pages/pipelines/stream_connections.html#stream-connections
Check also you processing order, Message Filter Chain and Pipeline Processor
You are right. Processing order is important.
Thanks.
