Percentage increase in count every n minutes
I have an alert that gets the count of messages from the last 10 minutes:
What I would like, is to somehow get this value back within Graylog, so that the next time it runs I can compare them. If the new value is let’s say 2x or more, it would trigger an email notification indicating a possible DDOS attack.
Writing a bash/py script to get this value via the API, doing calculations, and sending it back to Graylog would probably be the easiest way, but I would like to know if there’s a workaround/hack I can do here to keep everything within Graylog.
If this isn’t the best way to go about it I’ll glady listen to it.
TLDR; I want to send an alert if there’s been an increase of 100% in the message count over the last 10 minutes, compared to the 10 minutes beforehand.
Thanks. :slight_smile:
There has been a couple situation of other members wanting the same thing. I don’t know of a hack yet :wink:
But I do believe the Enterprise version might be capable of doing that for you, Its free under 2 GB per day.
You could also check here or add a feature request
Maybe someone else here has done this, might be a minute for a response thou. If I come across something Ill post it here.
I did come across an idea but this would pertain to installing some other features. Not sure if you want to go this far.
I enabled Prometheus on Graylog from here
Then I installed Grafana on Graylog from here
Created a dashboard for Graylog and since there is metrics, I can monitor my INPUT and Streams created. So if the percentage is greater then I wanted. Grafana is capable of send alerts. Below is an example of one stream that I have chosen.
Create alert
To be honest, it was very easy to setup. What I showed above is all on my Graylog server.
Thanks for the quick reply :slight_smile:
Although this definitely does work, it feels like more overhead than a simple script. My thinking behind that conclusion is that having two services running on one host could cause a much larger bloat in resource usage, which is something I would like to avoid. Plus, even if it is a simple installation there’s more to do compared to a script that calls an API, gets a value, and does one calculation.
For now I will try to go the script route, but leave this discussion open in case anyone has come up with an all around Graylog hack of sorts.
Thanks again for the help!
