I’m trying to parse the message below which comes into the full_message field on the GELF TCP input.
I’m having issues with creating an extractor on a multiline field, I have tried grok patterns with (?s) as suggested here but it didn’t seem to do anything. I also tried regex but its the same issue of only being able to use 1 line.
I also tried to use a pipeline but I’m having trouble figuring out the coding any help would be greatly appreciated. An example of how i might do it would be great too.
A directory service object was modified.
Subject:
Security ID: S-1-5-21-2204958825-1778247899-2594878194-3373
Account Name: user12
Account Domain: domain
Logon ID: 0x11D9404F4Directory Service:
Type: Active Directory Domain ServicesObject:
DN: CN=user name,OU=ExcludeFromPhoneDirectory,OU=IT,OU=domainUsers,OU=domainDomainResources,DC=domain,DC=local
GUID: {25DF5F5C-5E69-45A0-BDCF-41BDDF42B88B}
Class: userAttribute:
LDAP Display Name: userPrincipalName
Syntax (OID): 2.5.5.12
Value:user1@domain.comOperation:
Type: Value Added
Correlation ID: {43F7C446-9D4F-4FF9-A433-34DEC6ACBBB9}
Application Correlation ID: -
I’m looking for an output for each value ie.
Security ID
S-1-5-21-2204958825-1778247899-2594878194-3373Account Name
user12Account Domain
domainLogon ID
0x11D9404F4
