I’m currently trying to set up a local mirror of the graylog-repositories with aptly.
This fails, because no valid OpenPGP data is found (see below)
Comparing the graylog-repos with other repos I have mirrors for I see that the other --working-- repos have an “InRelease” File, that contains both, the Release Info and the signature.
https://packages.graylog2.org/debian/dists/stable does not have such a file at the time of writing this topic.
Now I don’t know wether to blame graylog or aptly.
Have you experienced similar issues and can you point me to a possible solution or workaround?
Thanks in advance!
aptly@myserver:~$ wget -O - https://packages.graylog2.org/repo/debian/dists/stable/Release.gpg | gpg --no-default-keyring --keyring trustedkeys.gpg --import --2019-12-10 10:02:04-- https://packages.graylog2.org/repo/debian/dists/stable/Release.gpg Auflösen des Hostnamens »packages.graylog2.org (packages.graylog2.org)« … 52.7.202.148, 54.224.175.112, 34.193.139.214, ... Verbindungsaufbau zu packages.graylog2.org (packages.graylog2.org)|52.7.202.148|:443 … verbunden. HTTP-Anforderung gesendet, auf Antwort wird gewartet … 302 Found Platz: https://graylog2-package-repository.s3.amazonaws.com/debian/dists/stable/Release.gpg?AWSAccessKeyId=AKIAIJSI6MCSPXFVDPIA&Expires=1575969125&Signature=ZYBmxL550VkhqnoVl3HCZrkjThk%3D [folgend] --2019-12-10 10:02:05-- https://graylog2-package-repository.s3.amazonaws.com/debian/dists/stable/Release.gpg?AWSAccessKeyId=AKIAIJSI6MCSPXFVDPIA&Expires=1575969125&Signature=ZYBmxL550VkhqnoVl3HCZrkjThk%3D Auflösen des Hostnamens »graylog2-package-repository.s3.amazonaws.com (graylog2-package-repository.s3.amazonaws.com)« … 52.218.106.162 Verbindungsaufbau zu graylog2-package-repository.s3.amazonaws.com (graylog2-package-repository.s3.amazonaws.com)|52.218.106.162|:443 … verbunden. HTTP-Anforderung gesendet, auf Antwort wird gewartet … 200 OK Länge: 473 [application/pgp-signature] Wird in »»STDOUT«« gespeichert. - 100%[======================================================================================================>] 473 --.-KB/s in 0,001s 2019-12-10 10:02:05 (759 KB/s) - auf die Standardausgabe geschrieben [473/473] gpg: no valid OpenPGP data found. gpg: Total number processed: 0
