Does graylog have a limit on the number of lines it can ingest into 1 log file in the message section of the log file in graylog?
Description of steps you’ve taken to attempt to solve the issue
I added the multi line options in my filebeat config so that it can ingest all my log file in 1 log file in filebeat. The log file on my server is an active log file so that means data gets appended to that file. While it is being appended that log file is sent via filebeat to graylog.
I did a test and copied over the same file but this time it was not active and had all the data in the log file. But then it only copied over certain amount of data not the whole file in 1 log file in graylog.
multiline.type
Defines which aggregation method to use. The default is pattern. The other option is count which lets you aggregate constant number of lines.
Here is some information for you if you haven’t seen it already.
Good Job.
I assume this is what solved your issue?
multiline.max_lines
The maximum number of lines that can be combined into one event. If the multiline message contains more than max_lines, any additional lines are discarded. The default is 500
