NSX Edge Firewall ( VMware )
@broerman
Download from Github
View on Github
Open Issues
Stargazers
Graylog extractor for VMWare Firewall NSXedge
VMware NSX firewall can ship its log via syslog protocol. A linux rsyslog server acts as gateway and sends logdata json formated to kafka message queue system.look here for an example
graylog fetch logs and extracts data, which are embedded in an JSON document.
The contents_pack consists of the input with parameters for
Content_pack parameters
| parameter | default_value |
| title | nsxedge |
| zookeeper | localhost:2181 |
| topic_search | ^nsxedge$ |
You can use extractor export below to upload in your environment. Then you have to adjust the “source_field” in extractor “nsxedge_get_json”.
